Saltar al contenido principal
Samsung NP510R5E-A01UB Battery Replacement
Qué necesitas
  1. Samsung NP510R5E-A01UB Battery Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Battery Replacement: paso 2, imagen 1 de 1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Battery Replacement: paso 3, imagen 1 de 2 Samsung NP510R5E-A01UB Battery Replacement: paso 3, imagen 2 de 2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Battery Replacement, Battery: paso 4, imagen 1 de 3 Samsung NP510R5E-A01UB Battery Replacement, Battery: paso 4, imagen 2 de 3 Samsung NP510R5E-A01UB Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Battery Replacement: paso 5, imagen 1 de 3 Samsung NP510R5E-A01UB Battery Replacement: paso 5, imagen 2 de 3 Samsung NP510R5E-A01UB Battery Replacement: paso 5, imagen 3 de 3
    • Use the screwdriver to remove the four 3.5mm long screws holding the battery in place. Then carefully pull the battery's connector cable out to remove the battery.
Conclusión
2 personas más completaron esta guía.
Brian Briggs
Miembro Desde 02/14/18
529 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S6-G5, Eyestone Spring 2018 Miembro de USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 2,403
