Saltar al contenido principal
Samsung NP36535C-S05US Key Replacement
Qué necesitas
  1. Samsung NP36535C-S05US Key Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US Key Replacement: paso 2, imagen 1 de 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US Key Replacement: paso 3, imagen 1 de 2 Samsung NP36535C-S05US Key Replacement: paso 3, imagen 2 de 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US Key Replacement, Key: paso 4, imagen 1 de 3 Samsung NP36535C-S05US Key Replacement, Key: paso 4, imagen 2 de 3 Samsung NP36535C-S05US Key Replacement, Key: paso 4, imagen 3 de 3
    • There is an outer and inner piece of the retainer. The outer retainer has two (2) grooves for the inner retainer's posts to sit in.
    • Place the inner retainer piece into the outer retainer piece by inserting the posts into the grooves on the outer retainer piece.
  5. Samsung NP36535C-S05US Key Replacement: paso 5, imagen 1 de 3 Samsung NP36535C-S05US Key Replacement: paso 5, imagen 2 de 3 Samsung NP36535C-S05US Key Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • There are two (2) grooves on the outer retainer that fit onto two (2) metal brackets on the key's designated space.
    • Use angled tweezers to place the assembled retainer onto the two (2) metal brackets on the keyboard.
  6. Samsung NP36535C-S05US Key Replacement: paso 6, imagen 1 de 3 Samsung NP36535C-S05US Key Replacement: paso 6, imagen 2 de 3 Samsung NP36535C-S05US Key Replacement: paso 6, imagen 3 de 3
    • Once the retainer is attached, press the key onto the retainer, it will make a snapping sound when in place.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 311
