Saltar al contenido principal
Samsung NP36535C-S05US Display Screen Replacement
Qué necesitas
  1. Samsung NP36535C-S05US Display Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US Display Screen Replacement: paso 2, imagen 1 de 1
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US Display Screen Replacement: paso 3, imagen 1 de 2 Samsung NP36535C-S05US Display Screen Replacement: paso 3, imagen 2 de 2
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US Display Screen Replacement, Display Screen: paso 4, imagen 1 de 3 Samsung NP36535C-S05US Display Screen Replacement, Display Screen: paso 4, imagen 2 de 3 Samsung NP36535C-S05US Display Screen Replacement, Display Screen: paso 4, imagen 3 de 3
    • Open the laptop.
    • Locate the two (2) screw covers.
    • Remove the screw covers with the metal spudger.
  5. Samsung NP36535C-S05US Display Screen Replacement: paso 5, imagen 1 de 1
    • Remove the two (2) 2.27 mm screws with the Philips #0 screwdriver.
  6. Samsung NP36535C-S05US Display Screen Replacement: paso 6, imagen 1 de 1
    • Carefully pry the front display cover off with a plastic prying tool.
  7. Samsung NP36535C-S05US Display Screen Replacement: paso 7, imagen 1 de 3 Samsung NP36535C-S05US Display Screen Replacement: paso 7, imagen 2 de 3 Samsung NP36535C-S05US Display Screen Replacement: paso 7, imagen 3 de 3
    • Locate the six (6) 2.39 mm screws on the display bracket.
    • Remove the four (4) screws on the left and right sides of the display bracket located near the base of the display with the Philips #0 screwdriver.
    • Remove the two (2) screws on the left and right sides of the display bracket located near the top of the display with the Phillips #0 screwdriver.
  8. Samsung NP36535C-S05US Display Screen Replacement: paso 8, imagen 1 de 1
    • Carefully remove the connector between the display and the display casing by pulling the connector away from its outlet.
  9. Samsung NP36535C-S05US Display Screen Replacement: paso 9, imagen 1 de 2 Samsung NP36535C-S05US Display Screen Replacement: paso 9, imagen 2 de 2
    • Locate the six (6) 1.85 mm screws on the left and right brackets holding the display in place.
    • Remove the screws on each side of the bracket, alternating sides when removing each screw with the Philips #0 screwdriver.
  10. Samsung NP36535C-S05US Display Screen Replacement: paso 10, imagen 1 de 3 Samsung NP36535C-S05US Display Screen Replacement: paso 10, imagen 2 de 3 Samsung NP36535C-S05US Display Screen Replacement: paso 10, imagen 3 de 3
    • Locate the display connector on the back of the display.
    • Carefully remove the tape on the display connector.
    • Remove the display connector by unplugging it from its outlet.
  11. Samsung NP36535C-S05US Display Screen Replacement: paso 11, imagen 1 de 3 Samsung NP36535C-S05US Display Screen Replacement: paso 11, imagen 2 de 3 Samsung NP36535C-S05US Display Screen Replacement: paso 11, imagen 3 de 3
    • Locate and remove the tape from the back of the display in the two (2) sections marked on the supporting image.
  12. Samsung NP36535C-S05US Display Screen Replacement: paso 12, imagen 1 de 1
    • You have successfully removed the display screen.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 389
