Saltar al contenido principal
Samsung NP350V5C-T02US Wifi card Replacement
Qué necesitas
  1. Samsung NP350V5C-T02US Wifi card Replacement, Wifi card: paso 1, imagen 1 de 1
    • Flip over the laptop so you are facing the backside.
  2. Samsung NP350V5C-T02US Wifi card Replacement: paso 2, imagen 1 de 3 Samsung NP350V5C-T02US Wifi card Replacement: paso 2, imagen 2 de 3 Samsung NP350V5C-T02US Wifi card Replacement: paso 2, imagen 3 de 3
    • Look for the compartment with the Wifi symbol on it.
    • Using the Phillips #1 screwdriver remove the M2.5X5 screw, located beside the Wifi Symbol.
    • Using the plastic spudger, carefully pry the Wifi panel off.
  3. Samsung NP350V5C-T02US Wifi card Replacement: paso 3, imagen 1 de 2 Samsung NP350V5C-T02US Wifi card Replacement: paso 3, imagen 2 de 2
    • Gently remove the two wires attached to the the Wifi card by using the plastic spudger to pry from underneath the attachment points.
    • Using the #2 Phillips screwdriver, remove the M2.5X3 mm screw holding in the Wifi card
  4. Samsung NP350V5C-T02US Wifi card Replacement: paso 4, imagen 1 de 2 Samsung NP350V5C-T02US Wifi card Replacement: paso 4, imagen 2 de 2
    • Using you hand, gently pull out the Wifi card.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 999
