Saltar al contenido principal
Samsung NP350V5C-T02US RAM Replacement
Qué necesitas
  1. Samsung NP350V5C-T02US RAM Replacement, ODD/HDD/Memory Cover: paso 1, imagen 1 de 1
    • Flip the laptop over so that the bottom is facing toward you.
  2. Samsung NP350V5C-T02US RAM Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
  3. Samsung NP350V5C-T02US RAM Replacement: paso 3, imagen 1 de 1
    • Using your hand slide the ODD/HDD/Memory panel off in a downward motion.
  4. Samsung NP350V5C-T02US RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Locate the RAM in the lower right hand corner.
  5. Samsung NP350V5C-T02US RAM Replacement: paso 5, imagen 1 de 1
    • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
    • Since there are two RAMs, remove the other one by using the same method.
  6. Samsung NP350V5C-T02US RAM Replacement: paso 6, imagen 1 de 1
    • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
Conclusión
Un comentario
Hello,
Thank you for all of the guides. I was curious if you know what the maximum amount of RAM that this laptop can be upgraded to?
On the Samsung site, it says the max is 8 GB, however the Intel site says 32 GB is the max for the processor.
Could the difference be the motherboard?
Thanks!
Will
Will Terfansky - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 975
