Saltar al contenido principal
Samsung NP350E5C-A02US Hard Drive Replacement
Qué necesitas
  1. Samsung NP350E5C-A02US Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Hard Drive Replacement: paso 2, imagen 1 de 1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Hard Drive Replacement: paso 3, imagen 1 de 1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Hard Drive Replacement, Hard drive and memory stick cover: paso 4, imagen 1 de 1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US Hard Drive Replacement: paso 5, imagen 1 de 1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US Hard Drive Replacement: paso 6, imagen 1 de 1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US Hard Drive Replacement, Hard Drive: paso 7, imagen 1 de 1
    • Slide the hard drive 1/4" towards the front of the laptop.
  8. Samsung NP350E5C-A02US Hard Drive Replacement: paso 8, imagen 1 de 1
    • Then, lift the drive up and out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 427
