Saltar al contenido principal
Samsung NP305E5A-A03US RAM Replacement
Qué necesitas
  1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US RAM Replacement: paso 2, imagen 1 de 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US RAM Replacement: paso 3, imagen 1 de 2 Samsung NP305E5A-A03US RAM Replacement: paso 3, imagen 2 de 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US RAM Replacement: paso 4, imagen 1 de 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US RAM Replacement: paso 5, imagen 1 de 2 Samsung NP305E5A-A03US RAM Replacement: paso 5, imagen 2 de 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US RAM Replacement: paso 6, imagen 1 de 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US RAM Replacement, RAM: paso 7, imagen 1 de 1
    • Place your thumbs on the metal tabs.
    • Push outwards on the metal tabs to release the RAM.
  8. Samsung NP305E5A-A03US RAM Replacement: paso 8, imagen 1 de 2 Samsung NP305E5A-A03US RAM Replacement: paso 8, imagen 2 de 2
    • Pull out the RAM towards you to remove it from the laptop.
Conclusión
2 personas más completaron esta guía.
Julia Dotter
Miembro Desde 10/31/16
224 Reputación
1 Guía escrita
Equipo
Baylor, Team 5-7, Williams Fall 2016 Miembro de Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 380
