Saltar al contenido principal
Samsung NP305E5A-A03US Optical Drive Replacement
Qué necesitas
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: paso 2, imagen 1 de 1
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: paso 3, imagen 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: paso 3, imagen 2 de 2
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: paso 4, imagen 1 de 1
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: paso 5, imagen 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: paso 5, imagen 2 de 2
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: paso 6, imagen 1 de 1
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: paso 7, imagen 1 de 1
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: paso 8, imagen 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: paso 8, imagen 2 de 2
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: paso 9, imagen 1 de 3 Samsung NP305E5A-A03US Optical Drive Replacement: paso 9, imagen 2 de 3 Samsung NP305E5A-A03US Optical Drive Replacement: paso 9, imagen 3 de 3
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: paso 10, imagen 1 de 2 Samsung NP305E5A-A03US Optical Drive Replacement: paso 10, imagen 2 de 2
    • Remove the Optical Drive by sliding it away from the laptop.
Conclusión
Una persona más ha completado esta guía.
Kris Stobbe
Miembro Desde 10/30/16
585 Reputación
3 Guías creadas
Equipo
Baylor, Team 5-7, Williams Fall 2016 Miembro de Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 442
