Saltar al contenido principal
Samsung NP305E5A-A03US Battery Replacement
  1. Samsung NP305E5A-A03US Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Battery Replacement: paso 2, imagen 1 de 1
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Battery Replacement: paso 3, imagen 1 de 2 Samsung NP305E5A-A03US Battery Replacement: paso 3, imagen 2 de 2
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
Conclusión
3 personas más completaron esta guía.
Kris Stobbe
Miembro Desde 10/30/16
585 Reputación
3 Guías creadas
Equipo
Baylor, Team 5-7, Williams Fall 2016 Miembro de Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
Miembros de 3
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 676
