Saltar al contenido principal
Samsung NP300E5C Hard Drive Replacement
Qué necesitas
  1. Samsung NP300E5C Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Hard Drive Replacement: paso 2, imagen 1 de 3 Samsung NP300E5C Hard Drive Replacement: paso 2, imagen 2 de 3 Samsung NP300E5C Hard Drive Replacement: paso 2, imagen 3 de 3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Samsung NP300E5C Hard Drive Replacement: paso 4, imagen 1 de 3 Samsung NP300E5C Hard Drive Replacement: paso 4, imagen 2 de 3 Samsung NP300E5C Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Samsung NP300E5C Hard Drive Replacement: paso 5, imagen 1 de 2 Samsung NP300E5C Hard Drive Replacement: paso 5, imagen 2 de 2
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
Conclusión
11 personas más completaron esta guía.
aliahsan95
Miembro Desde 09/23/15
937 Reputación
4 Guías creadas
Equipo
Baylor, Team 10-13, Williams Fall 2015 Miembro de Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Miembros
4 Guías creadas
2 comentarios
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - Contestar
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 49
Todo El Tiempo: 12,372
