Saltar al contenido principal
Samsung NP270E5E-K03US RAM Replacement
Qué necesitas
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: paso 1, imagen 1 de 2 Samsung NP270E5E-K03US RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: paso 2, imagen 1 de 2 Samsung NP270E5E-K03US RAM Replacement: paso 2, imagen 2 de 2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: paso 4, imagen 1 de 3 Samsung NP270E5E-K03US RAM Replacement: paso 4, imagen 2 de 3 Samsung NP270E5E-K03US RAM Replacement: paso 4, imagen 3 de 3
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: paso 5, imagen 1 de 3 Samsung NP270E5E-K03US RAM Replacement: paso 5, imagen 2 de 3 Samsung NP270E5E-K03US RAM Replacement: paso 5, imagen 3 de 3
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: paso 6, imagen 1 de 1
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
Conclusión
Una persona más ha completado esta guía.
Kyle Golden
Miembro Desde 03/23/17
353 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 1,066
