Saltar al contenido principal
Samsung NP-R540-JA09US RAM Replacement
Qué necesitas
  1. Samsung NP-R540-JA09US RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US RAM Replacement: paso 2, imagen 1 de 1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US RAM Replacement: paso 3, imagen 1 de 2 Samsung NP-R540-JA09US RAM Replacement: paso 3, imagen 2 de 2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Unscrew and remove the two screws from the back panel labeled "Memory" with a Phillips #0 screwdriver.
  5. Samsung NP-R540-JA09US RAM Replacement: paso 5, imagen 1 de 1
    • Place the flat end of the spudger or your fingers, if possible, between the panel and the laptop. Pry the panel by moving the spudger up and down until the panel can be removed.
  6. Samsung NP-R540-JA09US RAM Replacement: paso 6, imagen 1 de 2 Samsung NP-R540-JA09US RAM Replacement: paso 6, imagen 2 de 2
    • Release the two holding pins by pushing them away from each other with your fingers or a spudger.
  7. Samsung NP-R540-JA09US RAM Replacement: paso 7, imagen 1 de 1
    • Pull the RAM out of the laptop with your fingers by gently lifting it up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 544
