Saltar al contenido principal
Samsung NP-R540-JA09US Hard Drive Replacement
Qué necesitas
  1. Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Flip the device to the bottoms-up position and locate the panel that says HDD.
    • In case of damage to panel, the HDD panel is just immediately right of the optical drive, and opposite from the battery
  2. Samsung NP-R540-JA09US Hard Drive Replacement: paso 2, imagen 1 de 3 Samsung NP-R540-JA09US Hard Drive Replacement: paso 2, imagen 2 de 3 Samsung NP-R540-JA09US Hard Drive Replacement: paso 2, imagen 3 de 3
    • Remove the two 3.7mm securing screws with a Phillips #0 screwdriver.
    • After removing the screws, remove the panel covering the HDD.
  3. Samsung NP-R540-JA09US Hard Drive Replacement: paso 3, imagen 1 de 3 Samsung NP-R540-JA09US Hard Drive Replacement: paso 3, imagen 2 de 3 Samsung NP-R540-JA09US Hard Drive Replacement: paso 3, imagen 3 de 3
    • Remove the screws on the bracket and then remove the bracket by pulling up.
    • Once the bracket has been removed, slide the hard drive towards the gap in the cavity and then remove it from the device.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 16
Todo El Tiempo: 934
