Saltar al contenido principal
Introducción
Use this guide to remove the front panel of your laptop to access the inner components of your device.
  1. Turn off laptop before starting.
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Pull the two latches outward.
    • Pull the two latches outward.
  3. Slide the battery out of the laptop. Slide the battery out of the laptop.
    • Slide the battery out of the laptop.
  4. Remove securing screw with the PH0 head.
    • Remove securing screw with the PH0 head.
  5. Slide the optical drive out and remove it from the device.
    • Slide the optical drive out and remove it from the device.
  6. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  7. Remove the two Phillips #0 screws labeled KBD.
    • Remove the two Phillips #0 screws labeled KBD.
  8. Open top panel by inserting an Opening Tool and going around the entire panel. Open top panel by inserting an Opening Tool and going around the entire panel.
    • Open top panel by inserting an Opening Tool and going around the entire panel.
  9. With the panel open, pop the keyboard out with your fingers or an opening tool.
    • With the panel open, pop the keyboard out with your fingers or an opening tool.
    • Make sure to pry the metal keyboard base and not the keycaps.
  10. Now move your hand around the keyboard to remove  the keyboard.
    • Now move your hand around the keyboard to remove the keyboard.
  11. Disconnect the keyboard cable from the motherboard. Disconnect the keyboard cable from the motherboard.
    • Disconnect the keyboard cable from the motherboard.
  12. Remove the two screws with a Phillips #00 screwdriver.
    • Remove the two screws with a Phillips #00 screwdriver.
  13. Remove the highlighted screws with a Phillips #0 Screwdriver.
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  14. Pry the front panel away from the base with an Opening Tool. Pry the front panel away from the base with an Opening Tool. Pry the front panel away from the base with an Opening Tool.
    • Pry the front panel away from the base with an Opening Tool.
  15. Disconnect the speaker wire from the motherboard. Disconnect the speaker wire from the motherboard.
    • Disconnect the speaker wire from the motherboard.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 70
