Saltar al contenido principal
Samsung NP-NC10-KA02US RAM Replacement
Qué necesitas
  1. Samsung NP-NC10-KA02US RAM Replacement, Battery: paso 1, imagen 1 de 2 Samsung NP-NC10-KA02US RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US RAM Replacement: paso 2, imagen 1 de 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US RAM Replacement: paso 3, imagen 1 de 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US RAM Replacement, Back Plate: paso 4, imagen 1 de 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US RAM Replacement: paso 5, imagen 1 de 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US RAM Replacement: paso 6, imagen 1 de 2 Samsung NP-NC10-KA02US RAM Replacement: paso 6, imagen 2 de 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
  7. Samsung NP-NC10-KA02US RAM Replacement, Fan: paso 7, imagen 1 de 2 Samsung NP-NC10-KA02US RAM Replacement, Fan: paso 7, imagen 2 de 2
    • Remove the three screws holding the fan using a 3.9mm screwdriver.
    • All three screws need to be removed in order to continue on to next step.
  8. Samsung NP-NC10-KA02US RAM Replacement: paso 8, imagen 1 de 1
    • Unplug the wires connected to the fan using a plastic opening tool.
  9. Samsung NP-NC10-KA02US RAM Replacement: paso 9, imagen 1 de 1
    • You are now able to carefully detach the fan from the base.
  10. Samsung NP-NC10-KA02US RAM Replacement, RAM: paso 10, imagen 1 de 1
    • After detaching the fan, you are now able to remove the RAM by extending the two side bars out
    • During this process, the computer needs to be shut off. Other components could be damaged and the computer would not be able to recognize the RAM properly.
  11. Samsung NP-NC10-KA02US RAM Replacement: paso 11, imagen 1 de 2 Samsung NP-NC10-KA02US RAM Replacement: paso 11, imagen 2 de 2
    • With the bars extended, you are now able to slide the RAM off the base.
Conclusión
3 personas más completaron esta guía.
JHOAN USECHE
Miembro Desde 10/03/16
372 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Miembros
6 Guías creadas
Un comentario
There is a small lid with one screw for RAM replacement. No need to remove all the bottom part.
D Akimov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 440
