Saltar al contenido principal
Samsung NP-NC10-KA02US Back Plate Replacement
Qué necesitas
  1. Samsung NP-NC10-KA02US Back Plate Replacement, Battery: paso 1, imagen 1 de 2 Samsung NP-NC10-KA02US Back Plate Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Back Plate Replacement: paso 2, imagen 1 de 1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Back Plate Replacement: paso 3, imagen 1 de 1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Back Plate Replacement, Back Plate: paso 4, imagen 1 de 1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Back Plate Replacement: paso 5, imagen 1 de 1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Back Plate Replacement: paso 6, imagen 1 de 2 Samsung NP-NC10-KA02US Back Plate Replacement: paso 6, imagen 2 de 2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
Linea de Meta
3 personas más completaron esta guía.
Brian Smith
Miembro Desde 10/03/16
405 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 1-1, Sullivan Fall 2016 Miembro de USF Tampa, Team 1-1, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G1
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 394
