Saltar al contenido principal
Samsung NP-N145-JP02US Screen Replacement
Qué necesitas
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: paso 1, imagen 1 de 1
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: paso 3, imagen 1 de 1
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: paso 4, imagen 1 de 3 Samsung NP-N145-JP02US Screen Replacement: paso 4, imagen 2 de 3 Samsung NP-N145-JP02US Screen Replacement: paso 4, imagen 3 de 3
    • Using your fingertips, gently pull screen to pop it out of the frame.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 444
