Saltar al contenido principal
Samsung NP-N145-JP02US Fan Replacement
Qué necesitas
  1. Samsung NP-N145-JP02US Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Before starting the replacement, turn off the device sure and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Fan Replacement: paso 2, imagen 1 de 1
    • Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
    • Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
  3. Samsung NP-N145-JP02US Fan Replacement: paso 3, imagen 1 de 1
    • Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
  4. Samsung NP-N145-JP02US Fan Replacement: paso 4, imagen 1 de 1
    • Manually remove the fan from the device by pulling out the connector.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 592
