Saltar al contenido principal
Samsung NP-N102S-B05PH Speaker Replacement
Qué necesitas
  1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Place the laptop face-down on a stable surface.
    • Remove the nine 6.5mm Phillips #0 screws shown.
    • Use the blue opening tool to gently pry the back of the laptop off of the body.
  2. Samsung NP-N102S-B05PH Speaker Replacement: paso 2, imagen 1 de 3 Samsung NP-N102S-B05PH Speaker Replacement: paso 2, imagen 2 de 3 Samsung NP-N102S-B05PH Speaker Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the six 4.5mm screws holding the motherboard to the case.
  3. Samsung NP-N102S-B05PH Speaker Replacement: paso 3, imagen 1 de 2 Samsung NP-N102S-B05PH Speaker Replacement: paso 3, imagen 2 de 2
    • Use the spudger to remove the red and black cable located above the speaker from it's connector.
    • Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
    • Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
  4. Samsung NP-N102S-B05PH Speaker Replacement: paso 4, imagen 1 de 1
    • Gently unhook the red and black wires from the plastic clips holding them to the case. This can be done with only your fingers.
  5. Samsung NP-N102S-B05PH Speaker Replacement: paso 5, imagen 1 de 1
    • Using the spudger, lift the speaker up and out of it's holder, as shown. The yellow plastic tape should peel off as well.
Conclusión
Lennon Grimm
Miembro Desde 10/04/16
247 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-4, Nance Fall 2016 Miembro de USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,055
