Saltar al contenido principal
Samsung NP-N102S-B05PH Hard Drive Replacement
Qué necesitas
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Before replacing a hard drive, have a backup of original files if files are needed to be recovered afterward.
    • Power down your laptop, and position the laptop with the bottom cover facing upwards.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #0 screwdriver, remove the nine 6.5 mm screws.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use an opening to pry off the bottom cover, clips.
    • Potential for device damage. Before proceeding, be sure to be grounded, as existing static can be transferred and cause significant damage to the device. Wear an anti-static wristband for additional protection.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: paso 4, imagen 1 de 3 Samsung NP-N102S-B05PH Hard Drive Replacement: paso 4, imagen 2 de 3 Samsung NP-N102S-B05PH Hard Drive Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: paso 5, imagen 1 de 3 Samsung NP-N102S-B05PH Hard Drive Replacement: paso 5, imagen 2 de 3 Samsung NP-N102S-B05PH Hard Drive Replacement: paso 5, imagen 3 de 3
    • Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
    • The hard drive is now fully removed from the laptop.
Conclusión
Una persona más ha completado esta guía.
Daniel Rudzik
Miembro Desde 10/04/16
349 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-4, Nance Fall 2016 Miembro de USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 1,577
