Saltar al contenido principal
Samsung NP-130-JA01US RAM Replacement
Qué necesitas
  1. Samsung NP-130-JA01US RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US RAM Replacement: paso 2, imagen 1 de 2 Samsung NP-130-JA01US RAM Replacement: paso 2, imagen 2 de 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US RAM Replacement: paso 3, imagen 1 de 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US RAM Replacement, RAM: paso 4, imagen 1 de 2 Samsung NP-130-JA01US RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Locate the "Memory" panel on the bottom right corner.
    • Use the Phillips 01 screwdriver to remove the screw.
    • The screw is a Phillips 1 (PH 1) with a length of 60 millimeters (mm)
  5. Samsung NP-130-JA01US RAM Replacement: paso 5, imagen 1 de 1
    • With your hand, lift panel and remove it.
  6. Samsung NP-130-JA01US RAM Replacement: paso 6, imagen 1 de 2 Samsung NP-130-JA01US RAM Replacement: paso 6, imagen 2 de 2
    • Slide metal prongs (marked in red squares) away from each other with your fingers.
    • The RAM chip will automatically lift up at an angle for easy ejection.
  7. Samsung NP-130-JA01US RAM Replacement: paso 7, imagen 1 de 1
    • With your hands, carefully slide the RAM chip out to remove.
    • The RAM chip is delicate, do not force it when removing it.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 9-6, Lacy Fall 2016 Miembro de USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 198
