Introducción
Accessing the RAM in this laptop is straightforward and requires minimal disassembly. You can upgarde the ram for better performance. One RAM slot allows up to 2 GB of DDR2 PC2-5300 667MHz 200-pin SODIMM
Qué necesitas
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate and unscrew the 5mm screw on the small panel on the back that has 'memory' written on it.
Pull off the memory panel.
Una persona más ha completado esta guía.
