Saltar al contenido principal
Introducción
This will provide the necessary steps to remove the keyboard from the laptop. This process can be time consuming and takes a lot of patience when it comes to removing they keyboard without damaging it. Make sure to take your time and follow the instructions completely.
  1. Turn off the computer.
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
  2. Slide the left and right switch to the "unlocked" position. Slide the left and right switch to the "unlocked" position.
    • Slide the left and right switch to the "unlocked" position.
  3. While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer. While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
  4. Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
    • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
  5. Skip the upgrade.
    Descuento de $10 en tu factura de $50 con
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
  6. Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Apply pressure upwards till the back panel pops off.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  7. The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard. The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
    • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
  8. Double check that you removed the three 7mm screws for the keyboard in the process of removing the back panel
    • Double check that you removed the three 7mm screws for the keyboard in the process of removing the back panel
  9. Flip the computer over. Then, use the plastic opening tools or spudger tool to push in the four, plastic tabs located at the top of the keyboard.
    • Flip the computer over. Then, use the plastic opening tools or spudger tool to push in the four, plastic tabs located at the top of the keyboard.
  10. Remove the keyboard by gently pulling the top loose, and lifting the keyboard out.
    • Remove the keyboard by gently pulling the top loose, and lifting the keyboard out.
    • This step can be accomplished using your hands. However, if you are having trouble try using the plastic opening tools.
  11. Remove the keyboard completely from the bezel and locate the ribbon cable that connects the keyboard to the motherboard.
    • Remove the keyboard completely from the bezel and locate the ribbon cable that connects the keyboard to the motherboard.
  12. Gently lift up the grey latch on the ribbon cable that connects it to the motherboard. Finish, by removing the keyboard from the motherboard. Be extremly careful when unlatching the grey latch from the ribbon cable. It is very delicate and can easily be broken. Be extremly careful when unlatching the grey latch from the ribbon cable. It is very delicate and can easily be broken.
    • Gently lift up the grey latch on the ribbon cable that connects it to the motherboard. Finish, by removing the keyboard from the motherboard.
    • Be extremly careful when unlatching the grey latch from the ribbon cable. It is very delicate and can easily be broken.
Conclusión
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 30
Todo El Tiempo: 1,853
