Introducción
This guide will show you how to replace a faulty speaker.
Qué necesitas
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Casi Terminas!
Conclusión
