Saltar al contenido principal
Samsung Mythic SGH-a897 Speaker Replacement
Qué necesitas
  1. Samsung Mythic SGH-a897 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Speaker Replacement: paso 2, imagen 1 de 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Speaker Replacement, Rear Case: paso 3, imagen 1 de 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Speaker Replacement: paso 4, imagen 1 de 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Speaker Replacement, Speaker: paso 5, imagen 1 de 2 Samsung Mythic SGH-a897 Speaker Replacement, Speaker: paso 5, imagen 2 de 2
    • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Conclusión
Morgan Yost
Miembro Desde 04/08/13
46 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-1, Regan Spring 2013 Miembro de Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 236
