Saltar al contenido principal
Samsung Mythic SGH-a897 Motherboard Replacement
Qué necesitas
  1. Samsung Mythic SGH-a897 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Motherboard Replacement: paso 2, imagen 1 de 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Motherboard Replacement, Rear Case: paso 3, imagen 1 de 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Motherboard Replacement: paso 4, imagen 1 de 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Motherboard Replacement, Camera: paso 5, imagen 1 de 2 Samsung Mythic SGH-a897 Motherboard Replacement, Camera: paso 5, imagen 2 de 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 Motherboard Replacement: paso 7, imagen 1 de 2 Samsung Mythic SGH-a897 Motherboard Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 Motherboard Replacement: paso 9, imagen 1 de 2 Samsung Mythic SGH-a897 Motherboard Replacement: paso 9, imagen 2 de 2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 Motherboard Replacement: paso 10, imagen 1 de 2 Samsung Mythic SGH-a897 Motherboard Replacement: paso 10, imagen 2 de 2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 Motherboard Replacement: paso 11, imagen 1 de 1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 Motherboard Replacement: paso 12, imagen 1 de 2 Samsung Mythic SGH-a897 Motherboard Replacement: paso 12, imagen 2 de 2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 Motherboard Replacement: paso 13, imagen 1 de 2 Samsung Mythic SGH-a897 Motherboard Replacement: paso 13, imagen 2 de 2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
Conclusión
Morgan Yost
Miembro Desde 04/08/13
46 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-1, Regan Spring 2013 Miembro de Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 474
