Saltar al contenido principal
Samsung MV900F Screen Replacement
Qué necesitas
  1. Samsung MV900F Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Screen Replacement: paso 2, imagen 1 de 1
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Screen Replacement: paso 3, imagen 1 de 1
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Screen Replacement, Screen: paso 4, imagen 1 de 2 Samsung MV900F Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Screen Replacement: paso 5, imagen 1 de 2 Samsung MV900F Screen Replacement: paso 5, imagen 2 de 2
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Screen Replacement: paso 6, imagen 1 de 1
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Screen Replacement: paso 7, imagen 1 de 1
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Screen Replacement: paso 8, imagen 1 de 1
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Screen Replacement: paso 9, imagen 1 de 1
    • Remove the old screen.
Conclusión
To reassemble your device, follow these steps in reverse order.
Ethan Rowland
Miembro Desde 03/03/15
216 Reputación
2 Guías creadas
Un comentario
Anyone an Idea where I can buy a cheap new display for that cam?
Bernhard Prieler - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 844
