Saltar al contenido principal
Samsung ML2510 Side Cooling Fan Replacement
Qué necesitas
  1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: paso 1, imagen 1 de 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: paso 1, imagen 2 de 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: paso 1, imagen 3 de 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Side Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Side Cooling Fan Replacement: paso 3, imagen 1 de 3 Samsung ML2510 Side Cooling Fan Replacement: paso 3, imagen 2 de 3 Samsung ML2510 Side Cooling Fan Replacement: paso 3, imagen 3 de 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: paso 4, imagen 1 de 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: paso 4, imagen 2 de 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: paso 4, imagen 3 de 3
    • Locate the holes on the panel that are attached to the main body.
    • Remove the front panel by gently moving the holes from the pegs one by one.
  5. Samsung ML2510 Side Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Samsung ML2510 Side Cooling Fan Replacement: paso 6, imagen 1 de 3 Samsung ML2510 Side Cooling Fan Replacement: paso 6, imagen 2 de 3 Samsung ML2510 Side Cooling Fan Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Samsung ML2510 Side Cooling Fan Replacement: paso 7, imagen 1 de 3 Samsung ML2510 Side Cooling Fan Replacement: paso 7, imagen 2 de 3 Samsung ML2510 Side Cooling Fan Replacement: paso 7, imagen 3 de 3
    • Lift the right side-panel up from the raised stops.
    • Gently rotate the panel as indicated in the picture to remove the panel entirely.
  8. Samsung ML2510 Side Cooling Fan Replacement: paso 8, imagen 1 de 1
    • Poke out the side fan from the inside of the printer.
  9. Samsung ML2510 Side Cooling Fan Replacement: paso 9, imagen 1 de 1
    • Unplug the fan's wires from the side circuit board.
    • Replace the fan and reassemble the printer using reverse procedures.
Conclusión
2 personas más completaron esta guía.
bbaustin
Miembro Desde 10/12/11
268 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-18, Regan Fall 2011 Miembro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 2,515
