Saltar al contenido principal
Samsung ML2510 Power Button Replacement
Qué necesitas
  1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: paso 1, imagen 1 de 3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: paso 1, imagen 2 de 3 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: paso 1, imagen 3 de 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Power Button Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Power Button Replacement: paso 3, imagen 1 de 3 Samsung ML2510 Power Button Replacement: paso 3, imagen 2 de 3 Samsung ML2510 Power Button Replacement: paso 3, imagen 3 de 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Power Button Replacement, Power Button: paso 4, imagen 1 de 3 Samsung ML2510 Power Button Replacement, Power Button: paso 4, imagen 2 de 3 Samsung ML2510 Power Button Replacement, Power Button: paso 4, imagen 3 de 3
    • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
  5. Samsung ML2510 Power Button Replacement: paso 5, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
  6. Samsung ML2510 Power Button Replacement: paso 6, imagen 1 de 3 Samsung ML2510 Power Button Replacement: paso 6, imagen 2 de 3 Samsung ML2510 Power Button Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the last step to free the opposite side of the top panel.
    • Lift the top panel from the front to remove it entirely.
    • Turn over the top panel to reveal the button on the underside of the panel.
  7. Samsung ML2510 Power Button Replacement: paso 7, imagen 1 de 1
    • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
  8. Samsung ML2510 Power Button Replacement: paso 8, imagen 1 de 2 Samsung ML2510 Power Button Replacement: paso 8, imagen 2 de 2
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic holder.
    • Replace the button and reassemble the printer following the directions in reverse order.
Linea de Meta
2 personas más completaron esta guía.
bbaustin
Miembro Desde 10/12/11
268 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-18, Regan Fall 2011 Miembro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 3,138
