Introducción
You will be required to disassemble much of the printer and its casing. You will need to refer to the Removing Samsung ML2510 Back Panel repair guide.
Qué necesitas
Remove the top hinged panel by taking out the pins at the bottom of this panel.
Remove the front panel by gently moving the holes on the panel, one at a time, from the pegs attached to the main body of the printer.
Remove the cable attached to the motor.
The entire panel can be removed from the rest of the printer.
Use a Phillips #2 screwdriver to remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
Replace the motor and reassemble the printer by following the instructions in reverse order.
Una persona más ha completado esta guía.
