Saltar al contenido principal
Partes
No se especificaron partes.
  1. Lay the TV screen-side down on a flat, soft surface.
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
    • Slide the stand out from the bottom of the TV.
  3. Remove fifteen Phillips screws securing the rear case to the front. If present, remove four Phillips screws for the VESA mount.
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
Conclusión
3 personas más completaron esta guía.
Steven Carlton
Miembro Desde 19/08/13
590 Reputación
3 Guías creadas
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 7
Todo El Tiempo: 1,870
