Saltar al contenido principal
Samsung LA40R81BD 40in LCD TV Remote Control Disassembly
Qué necesitas
  1. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: paso 1, imagen 1 de 3 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: paso 1, imagen 2 de 3 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly, Remote control: paso 1, imagen 3 de 3
    • Remove batteries before you disassemble the remote
    • Use a case opening tool to gently split the upper and lower case
    • Work around the entire case until the 2 halves come apart completely
  2. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: paso 2, imagen 1 de 2 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: paso 2, imagen 2 de 2
    • Release the circuit board by gently pushing the plastic tab away from the board
    • Use minimal force to avoid breaking it
    • Lift circuit board off top cover to expose the rubber button membrane
    • Lift off the rubber button membrane
  3. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: paso 3, imagen 1 de 2 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: paso 3, imagen 2 de 2
    • During reassembly make sure that you correctly place the battery cover retainer on the read case
  4. Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: paso 4, imagen 1 de 2 Samsung LA40R81BD 40in LCD TV Remote Control Disassembly: paso 4, imagen 2 de 2
    • When placing rear cover back onto the assembled top cover make sure you correctly align the battery terminals with the slots in the cover
Conclusión
9 personas más completaron esta guía.
Richdave
Miembro Desde 04/09/10
32,018 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,506 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 24
Ultimos 30 días: 110
Todo El Tiempo: 36,115
