Saltar al contenido principal
Samsung Jack Speaker Replacement
Qué necesitas
  1. Samsung Jack Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Speaker Replacement: paso 2, imagen 1 de 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Speaker Replacement, Rear Case: paso 3, imagen 1 de 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Speaker Replacement: paso 4, imagen 1 de 3 Samsung Jack Speaker Replacement: paso 4, imagen 2 de 3 Samsung Jack Speaker Replacement: paso 4, imagen 3 de 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Speaker Replacement: paso 5, imagen 1 de 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Speaker Replacement, Speaker: paso 6, imagen 1 de 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Speaker Replacement: paso 7, imagen 1 de 2 Samsung Jack Speaker Replacement: paso 7, imagen 2 de 2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Speaker Replacement: paso 8, imagen 1 de 1
    • Lift the speaker out of its compartment.
Conclusión
Una persona más ha completado esta guía.
Paul Piller
Miembro Desde 04/12/11
56 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 24-57, Amido Spring 2011 Miembro de Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,746
