Introducción
Use this guide to remove the old keyboard and install a new one.
Qué necesitas
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Remove the power and volume buttons on the right side of the Motherboard.
Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
Una persona más ha completado esta guía.
