Introducción
How to remove & replace the phone's LCD flex cable.
Herramientas
Partes
No se especificaron partes.
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
To free the circuit board, remove the black wire that is holding it down.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove the 3 screws holding down the flex cable.
The screws are 2.0 mm in length.
The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
The keyboard slider frame will come off and the flex cable exposed, but not free.
2 personas más completaron esta guía.
