Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Samsung Impression Camera Replacement
Qué necesitas
  1. Samsung Impression Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Camera Replacement: paso 2, imagen 1 de 2 Samsung Impression Camera Replacement: paso 2, imagen 2 de 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Camera Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Camera Replacement: paso 4, imagen 1 de 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Camera Replacement, Circuit Board: paso 5, imagen 1 de 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  6. Samsung Impression Camera Replacement: paso 6, imagen 1 de 2 Samsung Impression Camera Replacement: paso 6, imagen 2 de 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
  7. Samsung Impression Camera Replacement, Camera: paso 7, imagen 1 de 2 Samsung Impression Camera Replacement, Camera: paso 7, imagen 2 de 2
    • Turn the circuit board over.
    • The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
    • Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
Conclusión
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
Miembros de 4
23 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 57
Todo El Tiempo: 1,867
