Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
How to remove & replace the phone's back speaker.
Partes
No se especificaron partes.
  1. Orient the phone with the screen facing down.
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Grip the battery on its sides, opposite the direction of the white arrow. Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
    • Grip the battery on its sides, opposite the direction of the white arrow.
    • Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
  3. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  4. Remove the 6 outer screws.
    • Remove the 6 outer screws.
    • The screws should be 3.5 mm in length.
    • Put the screws in a safe place as they are very small and easy to lose.
  5. Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and are prone to fall out, so put these in a safe place.
  6. Remove the back speaker by carefully lifting it up.
    • Remove the back speaker by carefully lifting it up.
    • The speaker will still be attached to the circuit board by a wire and a small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece at the end of the wire.
Conclusión
3 personas más completaron esta guía.
Ross McKelvie
Miembro Desde 18/04/11
196 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,984
