Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
How to remove & replace the phone's back cover.
Partes
No se especificaron partes.
  1. Orient the phone with the screen facing down.
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Grip the battery on its sides, opposite the direction of the white arrow. Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
    • Grip the battery on its sides, opposite the direction of the white arrow.
    • Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Remove the 6 outer screws.
    • Remove the 6 outer screws.
    • The screws should be 3.5 mm in length.
    • Put the screws in a safe place as they are very small and easy to lose.
  5. Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and are prone to fall out, so put these in a safe place.
Conclusión
Saul Villatoro
Miembro Desde 25/04/11
255 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Miembros
22 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,564
