Saltar al contenido principal
Samsung Impression Antenna Replacement
Qué necesitas
  1. Samsung Impression Antenna Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Antenna Replacement: paso 2, imagen 1 de 2 Samsung Impression Antenna Replacement: paso 2, imagen 2 de 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Antenna Replacement, Back Cover: paso 3, imagen 1 de 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Antenna Replacement: paso 4, imagen 1 de 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Antenna Replacement, Circuit Board: paso 5, imagen 1 de 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression Antenna Replacement: paso 6, imagen 1 de 2 Samsung Impression Antenna Replacement: paso 6, imagen 2 de 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression Antenna Replacement, Antenna: paso 7, imagen 1 de 2 Samsung Impression Antenna Replacement, Antenna: paso 7, imagen 2 de 2
    • Remove the 3.9mm screw holding the bottom black piece (antenna assembly) into place.
    • The antenna assembly will snap off.
Conclusión
Una persona más ha completado esta guía.
Saul Villatoro
Miembro Desde 04/25/11
255 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 8-10, Regan Spring 2011 Miembro de Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Miembros
22 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,864
