Introducción
To replace USB port, remove battery first and then remove the USB port while connected to a wire.
Qué necesitas
To remove the wristband of the device, grab the middle loop and pull the band through.
Remove the four screws from the battery housing using a Phillips #00 screwdriver.
Use an iFixit opening tool to pry up the plastic cover.
Use tweezers to remove the wire from the slots.
Casi Terminas!
Conclusión
