Saltar al contenido principal
Samsung HMX-W300 Rear Case Replacement
Qué necesitas
  1. Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 3 de 3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Rear Case Replacement: paso 2, imagen 1 de 2 Samsung HMX-W300 Rear Case Replacement: paso 2, imagen 2 de 2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Rear Case Replacement: paso 3, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement: paso 3, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement: paso 3, imagen 3 de 3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Rear Case Replacement: paso 4, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement: paso 4, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement: paso 4, imagen 3 de 3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Rear Case Replacement: paso 5, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement: paso 5, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement: paso 5, imagen 3 de 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Rear Case Replacement, Remove tape.: paso 6, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement, Remove tape.: paso 6, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement, Remove tape.: paso 6, imagen 3 de 3
    • Use tweezers to remove the tape.
  7. Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: paso 7, imagen 1 de 2 Samsung HMX-W300 Rear Case Replacement, Unplug wire ribbon.: paso 7, imagen 2 de 2
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 Rear Case Replacement, Remove scerws.: paso 8, imagen 1 de 2 Samsung HMX-W300 Rear Case Replacement, Remove scerws.: paso 8, imagen 2 de 2
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 Rear Case Replacement: paso 9, imagen 1 de 1
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: paso 10, imagen 1 de 2 Samsung HMX-W300 Rear Case Replacement, Disconnect wire ribbon.: paso 10, imagen 2 de 2
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  11. Samsung HMX-W300 Rear Case Replacement, Remove screws.: paso 11, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement, Remove screws.: paso 11, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement, Remove screws.: paso 11, imagen 3 de 3
    • Use Phillips size 00 and remove the 3 screws as shown.
  12. Samsung HMX-W300 Rear Case Replacement, Pry screen.: paso 12, imagen 1 de 2 Samsung HMX-W300 Rear Case Replacement, Pry screen.: paso 12, imagen 2 de 2
    • Pry the end of the screen with the plastic opening tool.
  13. Samsung HMX-W300 Rear Case Replacement: paso 13, imagen 1 de 3 Samsung HMX-W300 Rear Case Replacement: paso 13, imagen 2 de 3 Samsung HMX-W300 Rear Case Replacement: paso 13, imagen 3 de 3
    • Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
  14. Samsung HMX-W300 Rear Case Replacement, Repalce rear case: paso 14, imagen 1 de 1
    • Removal of the rear case is completed.
Conclusión
Robert
Miembro Desde 01/21/15
966 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 9-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 262
