Saltar al contenido principal
Introducción
Shows how to replace motherboard with pictures and words. Removal of motherboard requires opening the camera and unscrewing screws from motherboard to remove from rear case.
  1. Samsung HMX-W300 Motherboard Replacement, Remove wristband: paso 1, imagen 1 de 3 Samsung HMX-W300 Motherboard Replacement, Remove wristband: paso 1, imagen 2 de 3 Samsung HMX-W300 Motherboard Replacement, Remove wristband: paso 1, imagen 3 de 3
    • To remove the wristband of the device, grab the middle loop and pull the band through (as shown in the picture).
  2. Samsung HMX-W300 Motherboard Replacement, Front case screw removal: paso 2, imagen 1 de 2 Samsung HMX-W300 Motherboard Replacement, Front case screw removal: paso 2, imagen 2 de 2
    • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Motherboard Replacement, Remove HDMI screw: paso 3, imagen 1 de 3 Samsung HMX-W300 Motherboard Replacement, Remove HDMI screw: paso 3, imagen 2 de 3 Samsung HMX-W300 Motherboard Replacement, Remove HDMI screw: paso 3, imagen 3 de 3
    • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a size #00 Phillips screwdriver.
  4. Samsung HMX-W300 Motherboard Replacement, Open front case.: paso 4, imagen 1 de 3 Samsung HMX-W300 Motherboard Replacement, Open front case.: paso 4, imagen 2 de 3 Samsung HMX-W300 Motherboard Replacement, Open front case.: paso 4, imagen 3 de 3
    • As shown in the picture, use the iFixit Opening Tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Motherboard Replacement, Unplug wire.: paso 5, imagen 1 de 3 Samsung HMX-W300 Motherboard Replacement, Unplug wire.: paso 5, imagen 2 de 3 Samsung HMX-W300 Motherboard Replacement, Unplug wire.: paso 5, imagen 3 de 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Motherboard Replacement, Remove tape.: paso 6, imagen 1 de 3 Samsung HMX-W300 Motherboard Replacement, Remove tape.: paso 6, imagen 2 de 3 Samsung HMX-W300 Motherboard Replacement, Remove tape.: paso 6, imagen 3 de 3
    • Use tweezers to remove the tape.
  7. Samsung HMX-W300 Motherboard Replacement, Unplug wire ribbon.: paso 7, imagen 1 de 2 Samsung HMX-W300 Motherboard Replacement, Unplug wire ribbon.: paso 7, imagen 2 de 2
    • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  8. Samsung HMX-W300 Motherboard Replacement, Remove scerws.: paso 8, imagen 1 de 2 Samsung HMX-W300 Motherboard Replacement, Remove scerws.: paso 8, imagen 2 de 2
    • There are 5 Phillips size 00 screws. Remove all 5 screws.
    • Wire ribbon is attached to the motherboard.
  9. Samsung HMX-W300 Motherboard Replacement: paso 9, imagen 1 de 1
    • Pry the motherboard up using the plastic opening tool.
    • Be careful there is a wire ribbon holding the motherboard.
  10. Samsung HMX-W300 Motherboard Replacement, Disconnect wire ribbon.: paso 10, imagen 1 de 2 Samsung HMX-W300 Motherboard Replacement, Disconnect wire ribbon.: paso 10, imagen 2 de 2
    • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Conclusión
Una persona más ha completado esta guía.
Robert
Miembro Desde 21/01/15
966 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 9-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 267
