Saltar al contenido principal
Samsung HMX-W300 Front Case Replacement
Qué necesitas
  1. Samsung HMX-W300 Front Case Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 1 de 3 Samsung HMX-W300 Front Case Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 2 de 3 Samsung HMX-W300 Front Case Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 3 de 3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Front Case Replacement: paso 2, imagen 1 de 2 Samsung HMX-W300 Front Case Replacement: paso 2, imagen 2 de 2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Front Case Replacement: paso 3, imagen 1 de 3 Samsung HMX-W300 Front Case Replacement: paso 3, imagen 2 de 3 Samsung HMX-W300 Front Case Replacement: paso 3, imagen 3 de 3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Front Case Replacement: paso 4, imagen 1 de 3 Samsung HMX-W300 Front Case Replacement: paso 4, imagen 2 de 3 Samsung HMX-W300 Front Case Replacement: paso 4, imagen 3 de 3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Front Case Replacement: paso 5, imagen 1 de 3 Samsung HMX-W300 Front Case Replacement: paso 5, imagen 2 de 3 Samsung HMX-W300 Front Case Replacement: paso 5, imagen 3 de 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Front Case Replacement, Battery: paso 6, imagen 1 de 2 Samsung HMX-W300 Front Case Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 Front Case Replacement: paso 7, imagen 1 de 1
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 Front Case Replacement: paso 8, imagen 1 de 3 Samsung HMX-W300 Front Case Replacement: paso 8, imagen 2 de 3 Samsung HMX-W300 Front Case Replacement: paso 8, imagen 3 de 3
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 Front Case Replacement, USB Port: paso 9, imagen 1 de 3 Samsung HMX-W300 Front Case Replacement, USB Port: paso 9, imagen 2 de 3 Samsung HMX-W300 Front Case Replacement, USB Port: paso 9, imagen 3 de 3
    • Use an iFixit opening tool to pry up the plastic cover.
    • Use tweezers to remove the wire from the slots.
  10. Samsung HMX-W300 Front Case Replacement: paso 10, imagen 1 de 2 Samsung HMX-W300 Front Case Replacement: paso 10, imagen 2 de 2
    • Remove both screws from the USB port using a Phillips #00 screwdriver.
  11. Samsung HMX-W300 Front Case Replacement: paso 11, imagen 1 de 2 Samsung HMX-W300 Front Case Replacement: paso 11, imagen 2 de 2
    • Push the USB port inside the case to remove it from the device.
  12. Samsung HMX-W300 Front Case Replacement, Front Case: paso 12, imagen 1 de 1
    • The front case is separated from the rest of the device.
Conclusión
Robert
Miembro Desde 01/21/15
966 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 9-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 308
