Saltar al contenido principal
Samsung HMX-W300 Battery Replacement
Qué necesitas
  1. Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 1 de 3 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 2 de 3 Samsung HMX-W300 Battery Replacement, Disassembling Samsung HMX-W300: paso 1, imagen 3 de 3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 Battery Replacement: paso 2, imagen 1 de 2 Samsung HMX-W300 Battery Replacement: paso 2, imagen 2 de 2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 Battery Replacement: paso 3, imagen 1 de 3 Samsung HMX-W300 Battery Replacement: paso 3, imagen 2 de 3 Samsung HMX-W300 Battery Replacement: paso 3, imagen 3 de 3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 Battery Replacement: paso 4, imagen 1 de 3 Samsung HMX-W300 Battery Replacement: paso 4, imagen 2 de 3 Samsung HMX-W300 Battery Replacement: paso 4, imagen 3 de 3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 Battery Replacement: paso 5, imagen 1 de 3 Samsung HMX-W300 Battery Replacement: paso 5, imagen 2 de 3 Samsung HMX-W300 Battery Replacement: paso 5, imagen 3 de 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 Battery Replacement, Battery: paso 6, imagen 1 de 2 Samsung HMX-W300 Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 Battery Replacement: paso 7, imagen 1 de 1
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 Battery Replacement: paso 8, imagen 1 de 3 Samsung HMX-W300 Battery Replacement: paso 8, imagen 2 de 3 Samsung HMX-W300 Battery Replacement: paso 8, imagen 3 de 3
    • After removing the battery housing, take the battery out.
Conclusión
6 personas más completaron esta guía.
Robert
Miembro Desde 01/21/15
966 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 9-2, Blackwell Winter 2015 Miembro de USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Miembros
16 Guías creadas
2 comentarios
What type of battery is this? What part number should we use to order a replacement?
VanDemark - Contestar
The type of battery should be printed on the case of the battery. Most likely it’s some type of lithium battery. The part number for the battery should be on the case as well. If you can’t find either of these on the battery case you can take the battery to a place that sales batteries and the personnel there should be able to tell you the type and part number for your battery.
Jarretti Reaves -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 2,111
