Introducción
To begin the replacement process for the speaker, the user will need to remove the outer casing. Then remove the motherboard, this will allow them to get to the speaker.
Qué necesitas
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Under the motherboard there is a metal plate that has to be removed.
Use a Phillips head #00 screwdriver to remove eleven 5mm screws.
