Introducción
To replace the motherboard, the user will need to remove the outer casing. This is done by removing removing screws fastening it in, then peeling a away the casing.
Qué necesitas
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Once inside the device, find the half that contains the motherboard of the device.
Casi Terminas!
Conclusión
