Introducción
The battery is located inside the camera. It will require uninstalling the battery housing, illustrated in the guide below.
Qué necesitas
Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
Remove the four 4.00mm screws holding the battery brace using a Phillips #00 screwdriver.
Casi Terminas!
Conclusión
