Saltar al contenido principal
Samsung HMX-F90 Strap Side Outer Casing Replacement
Qué necesitas
  1. Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: paso 1, imagen 1 de 3 Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: paso 1, imagen 2 de 3 Samsung HMX-F90 Strap Side Outer Casing Replacement, Battery: paso 1, imagen 3 de 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: paso 2, imagen 1 de 2 Samsung HMX-F90 Strap Side Outer Casing Replacement, Strap Side Outer Casing: paso 2, imagen 2 de 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 3, imagen 1 de 2 Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 3, imagen 2 de 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 4, imagen 1 de 2 Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 4, imagen 2 de 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 5, imagen 1 de 3 Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 5, imagen 2 de 3 Samsung HMX-F90 Strap Side Outer Casing Replacement: paso 5, imagen 3 de 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
Conclusión
Una persona más ha completado esta guía.
Amir Harb
Miembro Desde 09/26/17
705 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S13-G1, Boczar Fall 2017 Miembro de USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 321
