Saltar al contenido principal
Samsung HMX-F90 Lens Replacement
Qué necesitas
  1. Samsung HMX-F90 Lens Replacement, Battery: paso 1, imagen 1 de 3 Samsung HMX-F90 Lens Replacement, Battery: paso 1, imagen 2 de 3 Samsung HMX-F90 Lens Replacement, Battery: paso 1, imagen 3 de 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: paso 2, imagen 1 de 2 Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: paso 2, imagen 2 de 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Lens Replacement: paso 3, imagen 1 de 2 Samsung HMX-F90 Lens Replacement: paso 3, imagen 2 de 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Lens Replacement: paso 4, imagen 1 de 2 Samsung HMX-F90 Lens Replacement: paso 4, imagen 2 de 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Lens Replacement: paso 5, imagen 1 de 3 Samsung HMX-F90 Lens Replacement: paso 5, imagen 2 de 3 Samsung HMX-F90 Lens Replacement: paso 5, imagen 3 de 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Lens Replacement, Lens: paso 6, imagen 1 de 2 Samsung HMX-F90 Lens Replacement, Lens: paso 6, imagen 2 de 2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  7. Samsung HMX-F90 Lens Replacement: paso 7, imagen 1 de 2 Samsung HMX-F90 Lens Replacement: paso 7, imagen 2 de 2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  8. Samsung HMX-F90 Lens Replacement: paso 8, imagen 1 de 2 Samsung HMX-F90 Lens Replacement: paso 8, imagen 2 de 2
    • Locate and remove the two 3.5mm Phillips #00 screws from the side of the camcorder.
  9. Samsung HMX-F90 Lens Replacement: paso 9, imagen 1 de 3 Samsung HMX-F90 Lens Replacement: paso 9, imagen 2 de 3 Samsung HMX-F90 Lens Replacement: paso 9, imagen 3 de 3
    • Gradually pry off the outer casing using a prying tool.
  10. Samsung HMX-F90 Lens Replacement: paso 10, imagen 1 de 3 Samsung HMX-F90 Lens Replacement: paso 10, imagen 2 de 3 Samsung HMX-F90 Lens Replacement: paso 10, imagen 3 de 3
    • Locate and remove the three 4mm Phillips #00 screws around the lens.
    • Gently remove the lens.
Conclusión
3 personas más completaron esta guía.
Amir Harb
Miembro Desde 09/26/17
705 Reputación
6 Guías creadas
Equipo
USF Tampa, Team S13-G1, Boczar Fall 2017 Miembro de USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 1,180
