Saltar al contenido principal
Samsung HD Pro Camera Lens Replacement
Qué necesitas
  1. Samsung HD Pro Camera Lens Replacement, Casing: paso 1, imagen 1 de 1
    • Locate a small opening around the front panel of the camera.
  2. Samsung HD Pro Camera Lens Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung HD Pro Camera Lens Replacement: paso 3, imagen 1 de 1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung HD Pro Camera Lens Replacement: paso 4, imagen 1 de 1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung HD Pro Camera Lens Replacement: paso 5, imagen 1 de 1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung HD Pro Camera Lens Replacement, Camera Lens: paso 6, imagen 1 de 1
    • Locate the camera lens and unscrew it with your hands.
  7. Samsung HD Pro Camera Lens Replacement: paso 7, imagen 1 de 1
    • Remove the washers between the lens and motherboard.
Conclusión
Hunter Wood
Miembro Desde 01/18/17
101 Reputación
1 Guía escrita
Un comentario
Where do you purchase a new lens?
Gary - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 873
